Page 1 of 1
Convention Maps Links (For your convenience)
PostPosted: Sat Apr 28, 2012 10:13 am
by Black Jack Rackham
Origins
While the convention may still be stuck in the 1990s, the convention center is not! They have updated their site with a cool new map you can check it out HERE
GenCon
As the granddaddy of all RPG Cons, you’d expect a lot of maps, and you’d be right, sort of.
GenCon has a map of the current layout of the dealers hall (in case you need to do any shopping). You can find that HERE.
The games are spread throughout Downtown Indy, so HERE is a map of all the locations you might need to know about.
Most of the maps are below, but the Marriott has pop-up maps that I can't link to, so HERE'S the page you can find them on.
NOTE!
As we generally are in the JW Marriott (which is not the Mariott that's described above), keep scrolling down to see the JW's maps that I downloaded.
Open Gaming Convention
Should have updated this when OGC moved, but I was remiss. Unfortunately, the Westford Regency doesn't do maps either. Easiest way to describe where we'll be though is east side of the building, second floor.
Rising Phoenix Con
The folks at the Doubletree sent me a pdf of their floorplan. Here it is for your perusing pleasure.
fact_sheet[1].pdf
(356.41 KiB) Downloaded 5165 times
Re: Convention Maps Links (For your convenience)
PostPosted: Wed May 08, 2013 3:43 pm
Here's some more GenCon Maps
This time the three floors of the JW Marriott
NOTE: Click on the maps to get a bigger pic.
PostPosted: Sat Jun 08, 2013 11:10 am
EDIT: I just discovered the Columbus Convention Center map link no longer worked so I found the new one and replaced the link.
PostPosted: Mon Dec 12, 2016 11:44 am
Both Total Con and OGC have switched locations since I last updated this, so I've added the map to TCs blurb and taken out the one for OGC. Finally, I removed CotC since Dave hasn't gone in a couple of years.
PostPosted: Mon Jan 09, 2017 9:57 pm
by salamanca
And it switched locations
PostPosted: Thu Jul 13, 2017 3:19 pm
Forgot to add this before Origins (since I don't usually make much use of multimedia during cons), but Origins has a new app out for i(stuff)* called (predictably) Origins. It has maps on it and the usual stuff one might expect from such things.
*don't know if they're also for other smartphones since I have a iPhone and by law am now precluded from owning anything not apple-fanboi approved.
PostPosted: Mon May 27, 2019 11:28 pm
Another year and another upgrade for the Hyatt's website making the maps useless and unavailable. BUT they forgot that NOTHING is ever deleted on the internet so I found a link to the 2012 map (which actually has the damn names). I updated the link above.
PostPosted: Thu May 30, 2019 3:38 pm
Edit: Marriott changed their web addy for the maps of their convention areas. So I added a link up at the top.
PostPosted: Mon Jan 13, 2020 4:11 pm
Since we're adding Rising Phoenix I thought I should get you all a map. They don't have one online but the folks I spoke with said they'd email me one. I will put it up as soon as I get it.
In other news I'll leave TotalCon up for a while (I still hope they'll see the light, but I'm not holding my breath).
PostPosted: Thu Jan 30, 2020 4:39 pm
Rising Phoenix Convention map is now here!
